TPIS AFPR?
Old Aug 8, 2008 | 11:09 PM
B4Camaro91's Avatar
Car: Stock 1991 B4C Camaro
Engine: 5.7 TPI
Axle/Gears: Stock 2.73
TPIS AFPR?
Is TPIS still around? Anyone use their AFPR? My stock ticks bad and the car runs rough, wanted to replace it. Who is the best to use now? Also what about the PROM, is it ok stock? My '91 has sat in the barn for a few years so Ive lost so knowledge on latest products. Thanks for the help.
Old Aug 9, 2008 | 07:32 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: TPIS AFPR?
TPIS is still around. I have one on my camaro right now as i was recommended to use it by the performance shop that i go to. They are good regulators. The downside you will hear on here is that the vacuum fitting on the top wants to break off or that it backed out and caused a leak. Be careful around it and it wont break, and locktight the fitting before you install the regulator. They are fairly inexpensive on ebay as thats where i got mine.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
