camshaft help
Old Aug 6, 2008 | 11:28 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
camshaft help
so after planning out my engine i have tried looking up as many camshaft threads as possible and i have come to my first option for a camshaft. still there are acouple things that im confused about that i didnt seem to find an answer to. im looking into this cam http://store.summitracing.com/partde...7&autoview=sku
its going into an 86 iroc z with a 305 tpi, headers, 3 inch exhaust to hooker aero chamber muffler. im planning it to be a street car but still make trips to the strip for some drags. so i want that best of both worlds, one thing im wondering is will 108 degrees of lobe separation be enough? i read the cam article and it said that would be good for an engine of this size, but others have said that using a 114 lobe separation cam would be better? so im kinda lost. also i know the cam i need has to be a hydraulic flat tappet but does there have to be a special one for tpi? or fuel injection? i keep coming across camshafts that say "not computer controlled compatible" so what does this all mean, does this cam i picked fit ? or do i need something else. thanks
Old Aug 7, 2008 | 02:39 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: camshaft help
"i read the cam article and it said that would be good for an engine of this size"
Were they talking about a carb or EFI engine?
A lot harder to tune EFI with small lobe separation , generally >112 recommended.
Old Aug 7, 2008 | 10:32 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: camshaft help
Use a comp xe256 ground on a 112 LSA....... Keep reading.
Old Aug 7, 2008 | 10:14 PM
Re: camshaft help
okay thanks yeah i found that 112 should be used in most street applications to keep the computer from going crazy
Old Aug 8, 2008 | 02:32 AM
Re: camshaft help
what about this one http://store.summitracing.com/partde...4&autoview=sku
Old Aug 9, 2008 | 11:36 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Re: camshaft help
That's one step smaller than the 256. I'd go with the 256, it'll make more power and be just as tame.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
