Need Help ASAP on FPR screws
Old Aug 9, 2008 | 03:04 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
OK,I give up. I have a 85 305 TPI/700r4 Camaro. I need to replace fuel pressure regulator diaphram and cannot find correct tork or whatever it is style socket to remove the top of the regulator. They look like a small tork with a little stem or nipple in the center. Anyone know what size or what type of tool is needed to remove this regulator cover? I also posted this question on General Engine/Tech
Old Aug 9, 2008 | 04:16 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: Need Help ASAP on FPR screws
its a tamper proof TORX.
Old Aug 9, 2008 | 04:42 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I drilled a hole in the center of the torx bit
Old Aug 9, 2008 | 06:03 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
geez , you can get a set of security torx bits for around $10 just about anywhere tools are sold . the size it most likely a T10 .
Old Aug 9, 2008 | 06:52 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I just took a regular size torx socket and drove it down some, breaking the post in the middle, then clean out hole and screw out bolts.
I've done that a couple times okay.
Old Aug 9, 2008 | 08:19 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks for your replys. Found #10 tamper proof tork bit at Ace.
Old Aug 9, 2008 | 08:35 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Just fyi, you can put a regular torx in it , itll go in just a hair deep, and tap it with a small hammer till it seats in there about half way or so. Its better to do this with the fpr off the car , on a table or bench.
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Lmancha96
Sep 25, 2015 08:11 PM
