bad tps? code 22
Old Aug 21, 2008 | 12:34 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
bad tps? code 22
was reading .710 (speed density) and 4.30 at wot. Got a code 22 after I had it smogged then it started jumping around from .20-.30 and 3.20-3.50 at wot. now its .0 and 2.50-2.80 at wot. Unplugged the third terminal its reading .250-3.20 jumping around. I believe its supposed to be a constant .5. any help is appreciated
Old Aug 21, 2008 | 09:00 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: bad tps? code 22
Justin,
I'm not familiar with Speed Density but on my car, the TPS sensor is a minimum of .54 and then goes up. It should never go below .54 since this should be the reading with the car off (throttle blades closed).
Hope this helps!
Cornholio7979
Sep 20, 2018 02:31 AM
chazman
Aug 28, 2018 03:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
