All A/C Delete Pully's Say 88-92????
Old Aug 21, 2008 | 11:56 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Every A/C delete pully I find is for 88-92 f-bodys. I have an 89 Iroc but it has a 85-86 motor. Any Info? Thanks.
James
Old Aug 22, 2008 | 01:06 AM
Guest
Guest
Posts: n/a
Re: All A/C Delete Pully's Say 88-92????
If you have the 85-86 accessories as well with v-belts, you just remove the belt and you're done.
Old Aug 22, 2008 | 01:34 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Didn't the serpentine belt system start in 1988 and v-belt was 1987 and earlier?
Old Aug 22, 2008 | 01:40 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Reid, that is correct. You only need an A/C delete pulley with the serpentine system. As Madmax said, on a v-belt system just remove the belt going to the A/C unit.
Old Aug 22, 2008 | 12:28 PM
Car: '89 IROC-Z
Engine: LSx
I have the serpentine setup, so they must have just took it off the original 89 motor that was in there. Cool, so I can do the pully, thanks for the info.
James
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
