02 sensor question
Old Aug 29, 2008 | 10:19 PM
runningagain's Avatar
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
02 sensor question
I have an 86 truck with a tpi 350. I installed headers and had the 02 bung welded on the top of where the collector connects. I just whatched a car show that stated if you move the 02 further away from the stock location the 02 sensor will not read correctly and the prom will have to be reprogrammed. The only difference I know is that the ecm won't go into closed loop, I have a heated 02 for that reson, is this true?
Old Aug 30, 2008 | 12:49 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: 02 sensor question
Good question. I'm not sure either, but I'd like to know since I'm having 02 issues myself. I have headers and the bung is in the same location
Old Aug 30, 2008 | 08:57 AM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
The idle is kind of rough, it runs ok, I will have to retune the prom.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
