15* BTC ?
Old Aug 30, 2008 | 09:31 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
15* BTC ?
Just out of curiosity what are most of you with mild to wild cams running for base timing.Mine is set at 15 and i think thats a lil too much for a mild cam and aluminum l98 heads with a angle valve job? I thought it should be around 10..maybe 12 max
Old Aug 30, 2008 | 11:57 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: 15* BTC ?
which means that you added 7 degrees to the ECM timing maps, unless you reprogrammed the ECM with the new setting.
I run 6° base timing, but I have fast burn heads, and yes the ECM is set to 6° as well.
Old Aug 31, 2008 | 09:01 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
Re: 15* BTC ?
I believe when the ecm was programmed it was set to 8* but it was so long ago i cant remember or find the documents i got with it and same for my cam specs :S but from what most people i know around here are saying 6-8* is normal on stock motors.
Old Aug 31, 2008 | 10:41 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Re: 15* BTC ?
I found an interesintg but distubring factor aswell.While using my timing light as I increased timing the car ran better and crisper throttle respone and picked up idle with the spout disconnected.When I checked the reading for base timing on my snap on timing light it was 33* btc.Im starting to think that maybe the timing chain is off.Anyone have ideas,Id really like to lock my timing in and not feel sluggish or backfire at idle or just the pressure of my foot on the gas pedal in gear
Old Sep 1, 2008 | 12:19 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: 15* BTC ?
Spout? Sounds like Ford nomenclature.
Do you mean the Set Timing Connector?
Don't let it confuse you, if the timing mark is strobing within the timing tab it has to be between 0-12° BDTC.
Old Sep 1, 2008 | 12:30 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
Re: 15* BTC ?
Thats what i mean.The connector that you unplug to set the base timing.i had the car running and it was fully warmed up,unplugged that connector and then i set my timing gun to 12* and turned the dizzy untill i saw the timing mark on the timing tab line up with 0.i tried this at a few different setting and all felt sluggish..backfired a lil.I got fed up and tried letting the car run with the spout disconnected and keep advancing base timing until it sounded happy.Then i kept my timing light pointed at the tab and when i adjusted it to about 30* i saw the timing mark again and by 33* it was then lined up at 0.I have a snap on digital timing light.
tpiroc
Apr 28, 2013 08:12 PM
tpiroc
Apr 1, 2010 07:40 AM
tpiroc
Mar 22, 2006 05:42 AM
sguy30
Nov 21, 2000 10:43 PM
