More Initial Timing with Aluminum Heads????
Old Sep 11, 2008 | 04:27 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
I just getting done with a intake, head, cam, swap (see sig) and have heard that you should run more initial timing with an aluminum heads....
I don't have a way of datalogging yet so I'm kinda in the dark about where the car is pulling timing out if it is actually pulling some out.
I have set my initial timing as close to 6* BTDC as I can.
Do you think that I should just keep bumping my timing up..... Some have said that they run as high as 14* initial timing.
I thought that the cumbustion process is better with these new heads which would mean that it needs less timing.
ANYBODY?????
Old Sep 11, 2008 | 05:51 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: More Initial Timing with Aluminum Heads????
Each engine is different.
I'm running 8 deg btdc.
Aluminum heads allow you to run more total timing due to the heat transfer rate being much better with AL vs. iron.
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
