'87 TPI Sputtering when in gear, but runs good in park!
Old Sep 10, 2008 | 09:30 PM
Fire87Chicken's Avatar
Hello I recently bought a '87 305 TPI Trans Am. When i first start the car it runs great, revs awesome and idles smooth. Then when in gear, It will take off sluggish, then will begin to completly die out before it gets a mile down the road and wont rise above 1200rpm without sputtering/backfiring and acting like its trying to shift gears but doesnt have enough power. I know it could be alot of little things causing this, is there anything very common that could cause this? the service engine light is on. ive had a 02 T/A and a 99 WS6 but never delt with this...thanks for your time!
-Roy
Old Sep 10, 2008 | 09:58 PM
njcamaro's Avatar
Car: 1987 iroc
Engine: 350 tpi
Axle/Gears: 4.10
Re: '87 TPI Sputtering when in gear, but runs good in park!
Iac probably should be replaced also check to see if the tr\hrottle body is clean if coked up black soot will act funny
Old Sep 11, 2008 | 10:11 PM
Im pretty sure its the mass airflow sensor
1992rs/ss
Jan 31, 2025 05:10 PM
specialized
Jun 18, 2022 09:26 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
justin57
Aug 20, 2015 07:05 PM
squiggy2
Aug 9, 2015 09:30 PM
