Is installing an inline fuel pump on '88 T/A possible?
Old Sep 13, 2008 | 03:43 PM
hotrodta57's Avatar
Car: 1988 T/A
Engine: L98 Highly modified
Transmission: TCI 700R4
I have an '88 T/A with 350 and lots of high performance parts. Just cranked it yesterday after a rebuild. Was trying to set idle this afternoon when suddenly engine wouldn't start. I realized my fuel pump wasn't coming on. Checked fuse then jumpered 12V to "A" wire on fuel pump relay and pump is not coming on. I replaced pump not to long ago and don't want to go through dropping the tank again. Can I install an inline pump in the system and forget about the intank pump?
Old Sep 13, 2008 | 08:15 PM
DarkShark's Avatar
Car: C3
Engine: GMPP w/TPI
Transmission: TH350
Re: Is installing an inline fuel pump on '88 T/A possible?
You really need to remove the in tank pump if you want to run an inline pump. You can't pull fuel through a bad in tank pump.
You could cut a nice access door in the rear so that you won't have to drop the tank. Search the forums and you'll see what others have done!
Old Sep 14, 2008 | 03:53 PM
hotrodta57's Avatar
Car: 1988 T/A
After sleeping on it I figure no choice but to drop the tank. Will look into installing a pickup tube in place of the pump and then getting an inline pump. Thanks for the help.
Old Sep 16, 2008 | 12:39 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
i have a walbro 255 pump forsale if your interested... check my post in the forsale thread!
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
