SLP runner ports?
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
SLP runner ports?
Does anyone know the daimeter of the plenum to runner gaskets for the SLP aluminum runners (the ones that are siamesed at the plenum)?
I'm porting my plenum and don't have a gasket set handy to measure.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: SLP runner ports?
diameter of the SLP ports are 1.66" stock is 1.40"-1.47" i believe. the tops are siamesed tho... so it looks like the sideways 8 or infinity symbol. the runners themselves are 1.66" they are just hogged out in the middle alil for the first 1"-1.5"
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I would suggest getting a set of gaskets. You use them to outlined the material to be removed. With out them you will be guessing.
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
