tpi build
Old Sep 17, 2008 | 05:23 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
tpi build
ok so i now have another camaro, 1988 standard. v6 mpfi 700r4.
motor is being replace with a 5.7 tpi, new/rebuilt stock(not sure i am buying it from a camaro maginize, but i do now its a stock replacement) the trans its being replaced with a t-5(used, unsure if i can get a wc though). the wireing harness has been chopped up and a new one will have to be put in and computer to. the exhaust, same thing. but its being replaced with 3" true dual cat. my questions:
1. fuel delivery, new pump? same lines?
2. will there be any problems with the frame? or anything little and unoticed to an amater like me?
3. what can i do to the motor so that it wont be embrassed at the track, but still be a daily driver.
i do expact some sarcasism, and thats ok. do searches, i will tell me what i need to look for though please. ofcourse any help is very apprecitated. budget is not poor but not rich, middle i guess make sense?
Old Sep 17, 2008 | 11:10 PM
JoNNyZ's Avatar
Car: 00 Dodge Ram,83 Camaro
Engine: Ls1 Carbed Drag Motor
Transmission: Turbo 400
Axle/Gears: Strange Dana 60 4:56
Re: tpi build
Hey,i have done this conversionon my 83. i had crossfire and so the fuel lines where not in the right spots. so i ran all new fuel line from the tank with a common tube bender and ran them up the frame. then i used a plastic fuel line kit that repairs plastic flexible lines,which are on the newer cars and such and made the lines from the frame to the fuel rail out of that. flexible and durable and it has quick disconnects on it. a little bit of work but it did the job. i had to do the wiring and the whole bit if you have any specific questions id be glad to help out.
Old Sep 18, 2008 | 01:02 AM
DARKmj16's Avatar
Engine: 305 tbi
Re: tpi build
thank you jonnyz, 1st question is whats the different between cross fire and tpi?
2. so the old fuel pump will work? did you have to add any regulators or anything extra like that?
and hows the frame doing? rear end the same to? i got stock 3.42s and i dont suppose you live near roanoke, hands on is the best way for me to learn, or let alone understand what people talk bout lol
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
