Feul issues (305 Tpi)
Car: 1987 Chevrolet Camaro
Engine: Vtec Killer
Transmission: the kind that loses Hondas in 1st.
Axle/Gears: the kind that turn the wheels
So im having fuel issues in my 87 Camaro 305 tpi Auto, I just installed 24# injectors, AFPR, 255 lph fuel pump, and a new fuel filter.
If I spray spray starter fluid it starts for a few seconds. All the fuel componts are new. I hooked up a fuel pressure guage and it goes up to 40 psi at start up, then bleeds down slowly down to 20 psi within 5-10 mins.
I do have a chip to run the 24# injectors
服务器基础知识
代理服务器基础知识: 代理服务器的类型一般有Http、Ftp、Socks、Telnet等代理服务器类型,Http、Ftp和Telnet代理服务器顾名思义就是分别代理网页浏览、文件传输和远程登录,而Socks是一种可遇不可求的全能代理——前面所有的功能它都可以实现 。Socks代理又分为Socks4和Socks5,Socks4代理只支持TCP协议(传输控制协议),Socks5代理支持TCP和UDP协议(用户数据报协议), 还支持各种身份验证机制,服务器端域名解析等。Socks4能干的Socks5都可以干反过来就不行了,如ICQ只能用Socks5代理。 主要的技术参数包括IP地址、服务端口、服务类型、验证状态、本地连接时间特性、注释六方面信息:例如10.48.72.2:80@HTTP$6&263,1987,2543#哈尔滨 10.48.72.2表示为代服务器的IP地址为10.48.72.2 :80“:”后的80表示该代理服务器的服务端口为80 (常见的端口有21、23、80、81、1080、3128、8080等) @HTTP“@“后的HTTP表示该代理服务器的类型为HTTP代理 $”$”后的数值表示代理服务器验证状态
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Feul issues (305 Tpi)
Sounds like you have a internal leak, You have to check if its the injectors or the FP regulator thats leaking. Do it smell fuel when you start it ?
EDIT: and what injectors are you using ?
Engine: Vtec Killer
brand new 24# svo injectors, and a AFPR with a new spring and seal.
it doesnt smell like fuel.
Car: 1989 IROC-Z
Could be leaky injectors, does it say Denso on the side ? if it does, they may have been sitting some years on the store and they stuck up...
start it and pull power 1 on 1 and see if t runs any worse when removing the power to the injectors. if it get worse, they speray, but if there is no change in rpm it may not firing..
Car: 89 iroc
Engine: l98
Transmission: tremec
these could have been made 5 yrs ago. The new SVO's are Bosch3.. Orderend a set of FIC 24 Bosch 3's.. going into tomorrow.. You get what you pay for. Blue Oval does not check injectors before they send them. They are not a injector shop, just a sales place. New injectors that cheep? there is always a reason. Buyer beware!
Sanjay
Aug 12, 2015 03:41 PM
