wat does your cars idle at???
Old Sep 19, 2008 | 06:30 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
wat does your cars idle at??? is 800rpm to much after fully warmed up? i am running stand alone, if that make a difference.
Old Sep 19, 2008 | 07:21 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: wat does your cars idle at???
My car idles around 700-800rpm with a mild cam fully warm.on cold startup it idles around 900..sometimes 1000 extremely cold and works its way down after a few mins.
Old Sep 19, 2008 | 07:42 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
When cold my maro idles at around 1500 when first started and then makes its way to around 750 when warmed up. Forgot to mention it's a stock RS with open element.
Old Sep 20, 2008 | 01:52 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Cold start, around 1450 then goes down to 750 fully warmed and PARK
With gear in its like 625 / 650 rpm..
Old Sep 20, 2008 | 02:49 AM
John81's Avatar
Car: 1991 Trans Am
If the stock tach is to be believed 1300 cold start, 700 when warmed up and in park, 600 in gear. Completely stock (as far as i know) except a K&N air filter.
Old Sep 20, 2008 | 04:39 AM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Mine is about 1500 at cold start and about 650 when at warm idle and 600 in gear.
Old Sep 20, 2008 | 06:29 AM
LUVN'NOS's Avatar
Mine is 800-900 cold start, 1200 very cold and 650-ish when warmed up, stock 1991 trans am
Old Sep 20, 2008 | 07:10 AM
DarkShark's Avatar
Car: C3
Engine: GMPP w/TPI
Transmission: TH350
Originally Posted by LUVN'NOS
Mine is 800-900 cold start, 1200 very cold and 650-ish when warmed up...
Same for my TPI.
Old Sep 20, 2008 | 07:23 AM
george 88gta's Avatar
LT4 hot cam, Vortec heads. Cold idle is 1200 (scanner shows desired RPM as 1182), after warm up it idles at 800-850 in gear. Scanner at that point shows desired idle as 900. Still running the stock torque converter.
Old Sep 20, 2008 | 07:47 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Same.
Old Sep 20, 2008 | 12:13 PM
SpiderViper's Avatar
Car: 1987 Iroc-Z
Engine: 5.7L SB
Transmission: TKO 500
Axle/Gears: 10 bolt 373's and a Detroit Locker
Mine is about 1100 and then down to 600 when warm and in drive
Old Sep 20, 2008 | 06:36 PM
jayk2k3's Avatar
Car: 85 camaro z28
cool, i feel better about my idle. mine is 800-850. just seemed a lil high
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
