O2 wire to ECU - am I splicing the right wire?
Old Sep 21, 2008 | 07:40 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I have an 89 5.7 TPI -
I think the O2 input to the ECU is a solid purple wire, grey connector (marked "D") pin 7. Does this sound correct? If I splice in an O2 signal right at this wire should it work, or is there something else in that circuit?
I can't get a reading in the ECU from the O2 and I am suspecting a wiring issue -
thanks in advance
Old Sep 22, 2008 | 04:03 PM
kooga's Avatar
Car: Camaro IROC-Z 89
Engine: 28xxx miles
Transmission: TH700
Axle/Gears: 2.77 BW
Re: O2 wire to ECU - am I splicing the right wire?
From my 89 service manual....
Ppl wire , o2 sensor signal D7 .
Tan wire , o2 sensor ground D6
And I dont think there is something else in that circuit.
Old Sep 22, 2008 | 04:49 PM
Car: 89 GTA
Transmission: 7004R
Thanks - bear with me if this is a stupid question - but the tan D6 O2 ground - where should I put this for testing purposes? Neg battery? Chassis?
thanks - been tracking down no O2 signal in ECU for too long to mention!
Old Sep 23, 2008 | 05:29 AM
Car: 89 GTA
Transmission: 7004R
I cut the tan wire and attached it to the body and instantly saw the O2 swinging - thanks for the help
Old Sep 23, 2008 | 10:34 AM
kooga's Avatar
Engine: 28xxx miles
Transmission: TH700
Axle/Gears: 2.77 BW
Good news The tan wire from the ecm is attached to the ground strap Rear of RH cylinder head . Maybe want to check that ground not being lose or bad connection causing some other issues in the future ...
eightsixseven
Dec 16, 2024 01:50 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
nuggie
Aug 25, 2015 01:27 PM
