Whats my normal vacuum, and where to test?
Old Sep 23, 2008 | 06:55 PM
mgray1982's Avatar
I suspect a vacuum leak, but I don't know which lines to test and what the numbers should be for each line.
I'm used to diesels that don't have so many lines.
Old Sep 25, 2008 | 04:50 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Whats my normal vacuum, and where to test?
I get 22" at idle on the port that feeds the fuel pressure regular on the left rear of the upper plenum.
Old Sep 26, 2008 | 06:06 PM
mgray1982's Avatar
Yeah I get about the same, 21-22 at various test locations. Haven't tested every line yet tho.
Old Sep 27, 2008 | 03:16 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
I get 20-22 depending on the AC is on or off.
Old Sep 27, 2008 | 03:46 AM
mgray1982's Avatar
So should it be the same number for every vacuum line and system, OTHER than the PCV-intake line?? I think I remember hearing that the PCV is a controlled vacuum, so the value might be lower.
But for every other line should I see the same value as I get when plugging directly into the intake?
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
