Common Car Question
Old Sep 28, 2008 | 08:15 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Common Car Question
When I start up my Z, all this white smokes pours out the back and it's a lot. I haven't had the oil changed in a while so is that the culprit?
Old Sep 28, 2008 | 08:35 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Re: Common Car Question
White smoke? And its a lot of white smoke? Sweet smelling maybe? Coolent is what I would say and think.
Old Sep 29, 2008 | 12:16 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
usualy means a head gasket or nicked water journal.
I'm sorry but nissan makes the "Z" chevy made a CAMARO or if you have to a Z28, not a Z sorry its just a pet peave of mine
Old Sep 29, 2008 | 10:46 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
The nissan "Z" true name translated is "my fair lady" so some smart marketing guy used the option numbers just like GM did. I don't know or care who was first. (240Z or Z28) My vette is a "Z51"
White smoke could be oil, Check the plugs.
Old Sep 29, 2008 | 05:24 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Pure white smoke is coolant, If its aliitle grey then I would say its probably oil.
Old Sep 29, 2008 | 10:38 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Yea it's grayish, I put a quart of oil in the car, do you think that's it?
5W-30? That's what it said on the engine oil cap.
Old Sep 30, 2008 | 02:42 PM
Pocket's Avatar
Car: 91 Trans Am
White smoke = coolant = head gasket or intake gasket
Black smoke = rich = fueling, timing or tuning issue
Blue smoke = oil = rings/valve seals
Check your oil level and your water level
One will show you where the problem is
Ghettobird52
Jul 5, 2024 11:18 PM
MustangBeater20
Oct 29, 2022 09:20 PM
86IROC112
Apr 9, 2016 10:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
