305 tpi on 350 tbi
Old Oct 3, 2008 | 07:59 AM
Jesse's87Z28's Avatar
305 tpi on 350 tbi
Just bought an 89 350 tbi can i put everything from my 305 tpi system on this motor. Can i keep the three fifty heads or is it better to keep the 305 heads? Any computer changes? Any injector changes?
Old Oct 3, 2008 | 06:07 PM
WS685ta's Avatar
Re: 305 tpi on 350 tbi
I would keep the 350 heads since the compression was a little higher on the late model 350. The swap shouldn't require any changes to the fuel injectors. It would run a little stronger with larger injectors but when you consider the cost and trouble it's not worth it unless you are trying to ring everylast horsepower out. I swapped my 85tpi to a 350 and it runs great.
Old Oct 3, 2008 | 07:21 PM
thanks man i will take your advice im not looking for every last drop yet just want to get it back on the road bolt on can come later but thanks again
Old Oct 4, 2008 | 06:35 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Completely different ECM's.
8 22lb injectors required for what is now a 350TPI vs 8 19lb injectors in a 305TPI.
Did I also mention that they have Completely different ECM's?
Old Oct 4, 2008 | 09:25 AM
WS685ta's Avatar
I didn't replace my ECM or injectors and mine runs great.
Old Oct 4, 2008 | 09:30 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I just re-read.
He's re-using the intake and just changing the shortblock.
The injectors should still be changed. 19lb injectors on a 350 will most likely run lean.
xkingcodex
Feb 12, 2020 07:43 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
