305 to 350 swap with TPI
Old Oct 7, 2008 | 07:23 PM
scoutsniper's Avatar
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
Hi. i wanna build my 4 bolt block that i got and put it in my camaro using the stock TPI. its gonna be like 9.5 to 1 and 2.02 heads. what do i need to change to run this with the TPI setup? i wanna be kinda cheap. and please dont use short hand. im new and i wanna know what the item your talking about is.
thanks alot.
P.S. could i just swap in my 2.02 heads for now? and not change anything?
Old Oct 7, 2008 | 08:28 PM
WS685ta's Avatar
Re: 305 to 350 swap with TPI
I swapped my car to a 350 and the only thing that had to be changed was the oil pan. Dipstick was on different sides. The 305 exhaust manifold on the driverside will not allow you to use a older 350 block which has the dipstick on the driverside. I had to use a oilpan that has the dipstick on the driversside of the pan. Hope I explained this to you because this can a problem and needs to be addressed before you install the engine.
Everything else bolted up
I don't think heads with 202 intake valves will fit on the small bore 305. The bore is to small.
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
