LS1 fuel tank in TPI car, questions
Old Oct 7, 2008 | 08:11 PM
Firebat's Avatar
I got a LT1-swapped car which uses the TPI sending unit, TPI fuel pump, and thirdgen gas tank. So, fuel-wise, its just like a TPI setup.
What I want to know is if anyone with TPI has made a plastic LS1 gas tank work. I'm wondering if there is a way to bypass the LS1 fuel pressure regulator that is in the tank, otherwise I have to get a sending unit or tank from a 99+ V6 f-body because the V6's didn't have FPR's in the tank.
As for the rest of the gas tank swap, I can figure out how to hook up the lines and the wires to get it functional.
Old Oct 12, 2008 | 12:54 AM
Firebat's Avatar
Re: LS1 fuel tank in TPI car, questions
Got the LS1 tank in:
https://www.thirdgen.org/forums/ltx-...ml#post3914764
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
