Bore Question.. Need information
Old Oct 8, 2008 | 05:40 PM
The Freak's Avatar
Car: 89 IROC-Z, 92 RS Hertiage, 99 RS
Engine: TPI,TBI
Im working on a 5.7 TPI from 92 camaro L98..
this is my first rebuild, and need some guide through. i measured through the cylinders one by one.. they all came out as a 4.040 to 4.042ish Looks like every cylinders are in the same size. So what does that mean? Would those be all right? need bore, or what?
Old Oct 8, 2008 | 07:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Bore Question.. Need information
If they're the same diameter in every direction all up and down the bores, then measure the pistons and calculate the piston-to-bore clearance. If it's within spec you could get away with a honing, otherwise it needs to be bored.
Old Oct 8, 2008 | 08:11 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
The standard bore for a 350 is 4.00 inches. Not forsure what the max is for boring a 350 before having problems.
ZEEYAA
Apr 16, 2023 08:29 PM
FormulasOnly
Jul 23, 2018 08:47 AM
tmellott89
Oct 14, 2015 02:06 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
hartsmike
Oct 2, 2015 07:11 AM
