speed density ? TBI to TPI
Car: 92 RS
Axle/Gears: 3.27 4 wheel disc
I am wanting to install a TPI on my 92 RS that has TBI I have a TPI set up off a 89 camaro is the 89 mas air or speed density and dose it even mater
Thanks Shawn
lnsper@mchsi.com
Thanks Shawn
lnsper@mchsi.com
Re: speed density ? TBI to TPI
89 and earlier will be Mass Airflow. 90-92 Will be Speed density. My suggestions is that you stick with what year of your car is to what year TPI set up your going with. Things easier that way but its up to you. Read around and you will find out alot more on this. Its very important. 89 and earlier does not just fit directly with 90-92.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
You can use the '89 TPI but you'll have to use a 90-92 speed density harness and ECM. You'll also have to drill and tap a hole for a third vacuum fitting on the plenum to keep the MAP,fuel pressure regulator and the other vaccum systems happy. This is required on the '89 since it only has 2, so if you actually used a 90-92 TPI this wouldn't be an issue.
Car: 1983 G20 Chevy
Transmission: 4L60
The Tan/White/Orange wire on the floor is the factory ALDL connection on fullsize vans. The Purple and Green wires go to the wideband controller that I installed behind the dash. Its all in thin wire loom and under carpet padding and carpet now.
Sanjay
Aug 12, 2015 03:41 PM
