ZZ4 Heads (463 castings) on an LB9 question
Old Oct 22, 2008 | 03:27 PM
1987CamaroZ28's Avatar
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
okay folks. i'm getting ready to buy aluminum heads for my LB9 (that will be ATI supercharged). I'm leaning towards getting the ZZ4 heads because they have screw in studs, LT4 springs (which will support my 500/510 lift cam) and there aren't many small valved-aluminum heads.
The ZZ4 heads don't have provisions for an EGR. Will not having the EGR, increase crankcase pressures? Does the EGR have anything to do with the crankcase pressure?
Thanks in advance!
Old Oct 22, 2008 | 03:35 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: ZZ4 Heads (463 castings) on an LB9 question
EGR has nothing to do with crankcase pressure.
Old Oct 23, 2008 | 08:27 AM
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Thanks for the feedback.
Old Oct 23, 2008 | 12:21 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I hate to nitpick and even I was guilty of this at one point in time. I aways assumed the GM part number was the same as the casting. 463 is the last 3 of the part number of the newest ZZ4 heads, but they still have the 113 casting number. I had my engine all togather when I mentioned the 463 casting, but in reality they are just modified 113s carrying the 463 part number.
http://www.jegs.com/i/GM+Performance...56463/10002/-1
Old Oct 23, 2008 | 02:48 PM
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
I see what you mean. I really did think I would see the last three numbers in the casting # as 463. I'm looking around on to get pics of the ZZ4 heads to confirm, but I understand your point. I'm glad you mentioned it because I would think i was ripped off if I bought a set of zz4 heads and the casting was 113.
Old Oct 26, 2008 | 02:17 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Hey guys,that is somEthing I`ve noticed from looking at the heads online or in magazines.I have read some of fasts post as well as others that say casting 463 and all.I`ve been wondering about that.So thats cleared up I guess.So they are all 113 castings and 463 is just the part number.Thought I was missing something.The new castings are supposed to be much better than the production ones.I have read posts where guys said they had bowl work,cleaned up radius,and back cut valves out of the box.I didnt even check mine before install so not sure if mine do.If you get them take a look and post up if they do.I`m gonna check mine out when I do an intake swap.
Old Oct 26, 2008 | 07:33 AM
the blur's Avatar
wouldn't that combination reduce compression ?
Old Oct 26, 2008 | 12:04 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
If your talking about the zz4 heads on a 305,I knowits a common mod and I`ve read the zz4 heads with the stock size valves is a known good setup for a 305.I think you should get the heads milled some.
Old Oct 26, 2008 | 04:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
TrickFlow has some really badass aluminum heads designed for the small-bore engines like the 305 and 283. They have 54cc chambers, 175cc ports, 1.94/1.50 valves, screw-in studs, etc... all the good stuff. They are heavily based on the 195cc/64cc heads.
You should check those out, they are probably the best 'small-bore' head on the market.
Old Oct 27, 2008 | 12:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Go with Air_Adam's suggestion. I wouldnt use the ZZ4 heads with a supercharged 305. They're too small of ports and bad flow.
Old Oct 27, 2008 | 12:43 PM
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
I really did consider the TF heads but I'm concerned with the small combustion chamber (54CCs) verses 58cc. I don't know how to calculate the difference in compression. I know it's marginal, but i was really trying to lower the compression if anything. Does anyone know approximately what the different would be? I know that's not an easy question to answer, since there are a few things that need to be considered. I'll take a look at them again, thanks.
Old Jan 26, 2009 | 02:44 AM
85birdy's Avatar
Car: 1985 Trans Am 305 TPI
Hi, I have a 305 TPI and was wondering if I should try these Trickflow heads you speak of, these heads combined with hooker shorty's, edelbrock high flow base plate + SLP runners and K&N intake would be great right? i originally wanted the ZZ4 113 heads but when i read this im leaning for these TF's
also if this setup is good and all could you recommend a good cam combination to go with these heads? thanks alot!!
lt500r55
Sep 1, 2021 01:30 PM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
