A/C to Manifold Brace
Old Nov 6, 2008 | 01:33 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
I installed an air conditioning pump bracket to intake manifold brace from TPI Parts. This eliminated an annoying vibration around 3000 RPM. The part can be found on the TPI Parts website under discontinued parts.
Old Dec 9, 2009 | 10:19 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: A/C to Manifold Brace
could you post a pic
I am looking to do the same and I have the brace but I dont know where it goes
thanks
Old Dec 22, 2009 | 10:54 AM
jamon8's Avatar
Engine: 350 tpi
please post pic
Old Dec 23, 2009 | 02:17 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I purchased the brace from GM when they offered it as a kit referenced in a TSB. It came with the fasteners as well as the double-ended stud for the water pump.
I had to grind it to clear the fuel line(s).
The TPI Parts brace might be different.
Edit: The brace you're talking about is for a serpentine set-up and not a v-belt like mine. Never mind.
Old Dec 23, 2009 | 08:47 AM
jamon8's Avatar
Engine: 350 tpi
thanks for the reply
I have the serp setup with the ac comp on the pass side
if anyone has a pic of this brackets location it would be very helpful
thanks
Old Dec 28, 2009 | 04:58 PM
jamon8's Avatar
Engine: 350 tpi
anyone
sailtexas186548
Feb 17, 2017 03:07 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
m00n420
Sep 11, 2015 02:39 PM
Ian Irvine
Sep 4, 2015 08:08 AM
