Idle Issue -Thoughts?
Old Nov 6, 2008 | 07:32 PM
91firebird350's Avatar
Car: 91 Firebird Formula 350
Engine: TPI 350
Axle/Gears: 3:23
Hey Guys
I just went thru my whole motor and replaces every sensor and hose on it jsut for good measures.
When i drive my car, its drives fine then it starts to jump up and down 100rpm. I changed the IAC and Checked the TPS aswell.
My car has 104k on it. I have yet to change the fuel filter. I was thinking that maybe i have a bad fuel injector or 2. there is a few that have a high pitch noise comming from then when the car is running. Im not up to speed on FI so yeah.
Is it common for Injectors to go bad.? Ive put in cleaner, and run high test.
Thanks for the help
Old Nov 6, 2008 | 09:08 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Idle Issue -Thoughts?
#1 Change your fuel filter
Old Nov 6, 2008 | 10:39 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
What he said ^^^^ :-)
Old Nov 9, 2008 | 02:05 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Originally Posted by 91firebird350
Hey Guys
Thanks for the help
OHM CHECK THOSE SHITTY MULTECS..
Old Nov 9, 2008 | 02:56 PM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
