305 dying, build or buy shortblock and what heads?
Old Nov 10, 2008 | 07:16 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
Thinking its getting about time to give up on hitting the ole 305 with spray and start working on getting a 350 built for the car. 305's starting to make a little racket which makes me nervous since there has probably been 25 bottles of nitrous through it.
This whole operation will be on a tight budget, and I've heard a lot of people beat the dead horse on this board about how 305's suck, and to build one is a complete waste of money so lets hear some opinions.
What heads should I run? Decent performing heads that are moderately priced to say the least. I most definitely don't want to build a nice 350 and put 305 heads on it. Thought about Pro-Comps but what will I have to do about headers since I have round port style headers??
Already got a Crane Powermax 2032, LS2 lifters, Timing chain, HP oil pump, and gaskets. I also have a used set of Speed Pro .030 over forged pistons with minimal skirt wear and a set of rods for a 350. Debating finding a crank and a roller block and having the motor built locally, or buying a crate short block. Anyone know of a decent priced roller short block??
Help me get out on a budget guys, I've heard that dead horse beat a million times so prove to me its worth building a 350 for a few extra bucks than to build this 305 and keep running low 8's in the eighth mile.
Old Nov 16, 2008 | 11:59 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
Re: 305 dying, build or buy shortblock and what heads?
Heard that 305's are junk on this board since day 1, and no body can come up with a budget 350 setup to compete with it?
I know someone can, this is just more or less a bump.
Old Nov 18, 2008 | 12:23 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
If you wanna build a 305 go ahead man but......
GMPP 350cid 4 bolt blocks= $750.oo through Summit
http://store.summitracing.com/partde...0&autoview=sku
Several different Rotating assemblies with different prices $650 Cast internals up to $1900 all forged
http://store.summitracing.com/partde...8&autoview=sku
Your always gonna have to spend good $$$ on heads..... take your pick.
Old Nov 18, 2008 | 04:25 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I don't think you understood what I am trying to say. I want to build a 350, so give me advise on what heads to put on it that are budget worthy and will work with my headers that I already have. I do not want to build a 305!!!!!!!!!!!!!!!!!!!!
Old Nov 18, 2008 | 09:06 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Wow ...... For someone that wants everybody else to do his homework for him your pretty testy.......
Some would say do a but I'm not gonna do that to a guy that doesn't know what he's doin........
I've already given some staight forward examples ie:
1) zz4 bare block $750.oo
2) Eagle Rotating Assembly 355ci $650.oo (good to 500Hp)
Now as far as heads are concerned the choices are almost endless.....
http://store.summitracing.com/partde...5&autoview=sku $325.oo each for 2.02/1.60" valves with 165cc intake port... Great torque head considering that cam is good till 5500 RPM and you TPI dies at 4800RPM
http://store.summitracing.com/partde...5&autoview=sku & your already looking at over $1000.oo the 180 cc intake port will breathe @ the expense of port velocity....
http://store.summitracing.com/partde...5&autoview=sku $830 for the pair OUCH... Has all the right stuff though. I would consider going with the 305 S/R Torquers though http://store.summitracing.com/partde...5&autoview=sku or shave the deck of these to raise the compression
Anyway you look at it Heads are expensive..... and if your gonna shell out a $1000.oo or more you might as well go aluminum. Try to stick with something in the smalller intake runner size 170cc being optimal for a stock TPI in my opinion. If you go much bigger than that you'll have a dog with poor throttle response that is a pain to drive around town. If you plan on swapping the original TPI (that chokes out around 4800 RPM), for something that inhales easier... go with a bigger intake port, keep in mind your cam characteristics.
By the way, it won't be cheaper to rebuild heads or a block that you may find because you get nickled and dimed into the poor house anyway..... You won't rebuild a head for $400.oo each and a worked over block will cost $1200 or more and it'll probably be a 2 bolt main...
So for around 2200.oo bucks your rockin So much for this game being cheap.... But remember for all that you have a rock solid block with a 4 bolt main, a new rotating assembly with forged rods, and brand spankin new heads that won't smoke for the next 12 years .....
and piece of mind.
Old Nov 19, 2008 | 02:52 AM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I wasn't being testy man, and trust me, I've done plenty of homework on this setup. Already considered the Summit heads, but I don't know about them. Also considered Pro Comp, I've got their 320cc heads on a big block 462, but it has yet to come together yet (slow *** machinist) and I've heard good and bad things about their small block heads.
I appreciate the reply, I was just looking for some suggestions and advise, not trying to get you to do my homework for me.
Thanks again.
Old Nov 19, 2008 | 05:32 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Since you make power through your cylinder heads why don't you spend the cash and go aluminum???
Edelbrock makes SBC heads with 60cc combustion chambers for increased Tq/Hp and have 165cc intake runners....
I would just hate to think that you'd do all the work and spend lots of $$$ and leave something on the table........ But I know there's always a budget...
I bought the S/R 305 heads 3 years ago and spent the rest of the time buying up other parts for my engine a little at a time.... so I know what it's like to work on a budget.
Unfortunately, over the 3 years plans changed and I decided to go with a better breathing intake which caused me to reconsider the smaller S/R heads, so I steped up to the AFR Eliminator 180's.......... there goes the budget again. Not that I'm complaining
Jake_92RS
Jan 28, 2020 10:37 PM
pimp2303
Jul 27, 2017 02:03 PM
italiano67
Dec 11, 2016 09:21 AM
apo_bailon15
Mar 28, 2016 05:20 AM
