tpi swap help on connectors and hoses.
Old Nov 12, 2008 | 01:45 AM
blackdemon89ta's Avatar
I'm pretty much done with my swap i need help though cause there are some connections that i can't figure out.
1. where does the evap canister connect to?
2. there is a sensor in the back bottom of the plenium what is it?
3. There is a sensor next to the temp sensor what is that one?
4. there looks like a water outlet in the back of the manifold next to the distributor where does that connect to? or do i plug it if i'm doing the coolant bypass?
5. the booster coil connections i found one that connects from the hareness does the second one connect to the distributor?
6. The battery cable has a wire that splices into 3 other wires 2 go to the hareness and the other one looks like it should go to the alternator?? or does it go somewhere else?
Thanks if anyone can help.
my car is an 89 trans am it was an LO3. NOW has a 72' 350
The tpi came from an 86 not sure from what though either vette or f-body
The TPI hareness is from an 89 camaro
Old Nov 12, 2008 | 01:34 PM
therealmark's Avatar
Re: tpi swap help on connectors and hoses.
Don't have all your answers but here's some hose routing info that should help with the evap canister.
http://lt1intake.com/files/vac_hose_routing.html
M.
Old Nov 12, 2008 | 02:11 PM
cool that helps with the hoses. thanks
Old Nov 12, 2008 | 03:03 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
The sensor at the back bottom of the plenum is the Intake Air Temp. sensor.
Old Nov 12, 2008 | 04:20 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
www.chevythunder.com has a ton of that info also. Try them.
gta90
Sep 15, 2015 04:00 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
