stock cam in tpi350
Old Nov 21, 2008 | 06:34 PM
77tpi nova's Avatar
stock cam in tpi350
this is an ez one for somebody. what is the cam specs for a 91 tpi350? is the gm hot cam a good upgrade or will i be throwing away alot of low end?
Old Nov 21, 2008 | 10:20 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: stock cam in tpi350
https://www.thirdgen.org/mods3
IMO, Loosing low-end depends if you're keeping a stock Tq converter.... keeping the TPI???
Lingenfelter stated in his book "modifying small block Chevy engines."
"when I have 2 cams of the same duration, I will choose the cam with the most lift"
LT4 Hotcam=
Operating Range: 1,800-5,800 RPM
Advertised Duration: Intake 279 Exhaust 287
Duration @ .050 : Intake 218 Exhaust 228
Lift with 1.5 Rockers: Intake .492" Exhaust .492"
Lift with 1.6 Rockers: Intake .525" Exhaust .525"
LSA: 112'
Comp Cams"XFI" 268 Hydraulic Roller Camshaft
Operating Range: 1800-5800 RPM
Advertised Duration: 268°/276°
Duration @ .050'' Lift: 218° Intake / 224° Exhaust
Lift: .570"/.565" w/1.6 Rockers
Lobe Separation Angle: 113°
Comp Cams "XFi" 260 Hydraulic Roller Cam
Operating Range: 1200-5200 RPM
Duration Advertised: 260° Intake / 270° Exhaust
Duration @ .050'' Lift: 210° Intake / 218° Exhaust
Valve Lift w/1.6 Rockers: .560'' Intake / .555'' Exhaust
If your keeping the stock intake and Torque converter the XFI 260 might be your best bet.... going with a higher stall and keeping the original TPI intake will just shorten your powerband.
the XFI 260 has a newer cam design with faster ramps, big lift and loads of time under the curve.
just my
Old Nov 22, 2008 | 09:05 AM
77tpi nova's Avatar
thanks this was just what i was looking for
Old Nov 22, 2008 | 04:38 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
make sure you know what lift your heads will tolerate before selecting a cam....
Unless you wanna do head work as well.
Old Nov 22, 2008 | 11:11 PM
77tpi nova's Avatar
thanks, i'll probally make due with stock for now, its not too bad for a stock cam, especially if i can come up with some 1.6s need all the torque i can get in this heavy *** car anyway
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
