No start
Old Nov 26, 2008 | 06:43 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
No start
This time I'm stuck. For the last week the car has been getting harder and harder to start. Now it will crank forever and not start. I replaced the fuel pressure regulator diaphragm because it ripped and let a bunch of gas flood the plenum through the vacuum line. I also just replaced the ignition control module because it had a code 42. It has spark, the injectors are firing but it won't start. If you give it about 1/3 throttle it will sputter but that's it. Any ideas?
Old Nov 26, 2008 | 06:57 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: No start
check your fuel pressure, sounds like the fuel pump is bad
Old Nov 26, 2008 | 07:01 PM
TPeye's Avatar
Engine: 350ci
Re: No start
when I turn they key to "run" the pressure is about 40
Old Nov 26, 2008 | 08:25 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: No start
injectors firing or not, you must ohm check those multec injectors. if any are below 10ohms call FIC (www.FuelInjectorconnection.com) and get the bosch 3 injectors.
Old Nov 26, 2008 | 09:09 PM
TPeye's Avatar
Engine: 350ci
Re: No start
I already have the Bosche III injectors from FIC. The Multecs died last year.
Old Nov 26, 2008 | 09:55 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Re: No start
then you have to look at ICM, fuel pump, fuel pump relay, etc
Old Nov 27, 2008 | 09:17 AM
TPeye's Avatar
Engine: 350ci
Re: No start
I found the problem. When I pulled the distributor cap to put in the ignition module, I put all of the plug wires back 1 spot off going all the way around. Thanks for the help anyway guys.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
