Almost ready to start but I have a few questions
Old Nov 27, 2008 | 05:22 PM
Harlyworkr's Avatar
I am working on my TPI powered truck and I have just a few simple questions. Question 1: On the bottom of the throttle body there is a water port broken off, can I get by without running the coolant through the throttle body? Question 2: 24# injectors, 58mm throttle body, 100psi fuel pump with a 40psi fuel regulator, will these numbers work together? Any suggestions or comments welcome. If someone has a goor routing diagram for vacuume and coolant, I sure could use them right about now.
Attached Thumbnails Almost ready to start but I have a few questions-update1.jpg   Almost ready to start but I have a few questions-update2.jpg   Almost ready to start but I have a few questions-update3.jpg
Old Nov 27, 2008 | 07:51 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Re: Almost ready to start but I have a few questions
You don't need to run the coolant lines to the throttle body. I've found that it runs better without the added heat to the intake. If this is a 350, the stock injectors are 22lb/hr, so running 24s will require a custom chip. The 58mm throttle body might kill a little of the low end grunt these engines are known for.
Old Nov 27, 2008 | 11:35 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I'm running 24s in mine and it's fine. The injector pulses are shorter, but that's OK. You might be a little rich when running open loop though. I use a heated O2 sensor so it's not in OL for very long.
Old Nov 28, 2008 | 12:43 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Yeah a 58mm is way to big, but it should not hurt you that much. Some say that doing the coolant bypass gives you more power, I yet to see any dyno results that prove it makes any difference
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
