1985 Trans Am High Idle
Old Dec 1, 2008 | 10:55 AM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
I have a 1985 Trans Am 305 TPI Auto with a high idle and when i go to put it in gear the tires spin and somtimes with brakes on. Could it be the Thermostat or Idle Air Control Valve? Thanks
Old Dec 1, 2008 | 04:57 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: 1985 Trans Am High Idle
Is your check engine light on? I would first try properly setting the IAC and idle speed. Directions here:
https://www.thirdgen.org/tpimod2
Also, verify that base timing is set correctly with a timing light - if it's too far advanced it could bump up the idle speed.
Old Dec 2, 2008 | 11:05 AM
gtp-1's Avatar
Keep in mind just how weak normal rear brakes are as well. And is the idle high after warm up or is this cold weather related.
Old Dec 2, 2008 | 02:46 PM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
After warm up and somtimes a little harder to start it takes more cranks or have to hold the key longer to start but yes does this when warm.
Reddeath210
Oct 6, 2015 08:20 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Dquickshift
Aug 12, 2015 06:21 PM
drathaar907
Aug 10, 2015 07:44 AM
