fuel feed line tpi
Old Dec 1, 2008 | 02:32 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
fuel feed line tpi
the rubber hose on the end of the fuel feed line that connects to the tpi with connectors on each end , is that a must have for pressure maybe or could i just use 2 hose clamps and a piece of hose from a ps cooler or someting like that?
there is no fuel coming out of the injectors. there is fuel there just not coming out.
Old Dec 1, 2008 | 06:40 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: fuel feed line tpi
No hose clamps and no P/S hose. Try some NOID lights and see if the injectors are firing. Also check the pressure at the rail.
Old Dec 3, 2008 | 06:13 PM
Engine: 350 for now
Transmission: wc t5
i have used noid lights and my injectors are working. what i was saying is the rubber hose on the end of the fuel feed line is missing. when i bought the car it wasent on it. I was asking what kind of hose could i use in its place? i have been to every junk yard in town and looked at every parts house and i can not find that hose.
Old Dec 4, 2008 | 06:55 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
You could try the Chevy dealer or Ebay. Another option would be to run braided stainless lines from the hard lines on the fender to the fuel rails.
Old Dec 6, 2008 | 11:57 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Yes you can use gasoline rated high pressure rubber hose, but because the hard line fittings to the fuel rails are female you'll need the male end with a short piece of hard line to allow clamping on a rubber hose.
You should be able to find the Saginaw fittings on other GM trucks, or cars with EFI, if not the Saginaw power steering pump (which is what GM uses) use the same fittings. Find a Express, or Astro van that uses hydoboost power brake assist it will have the fittings (males only) you just need to cut off the hard line ends and clamp the fuel hose on to them.
I may have the old line from my car if I do you can have them for the cost of shipping.
Notes:
  1. Only the saginaw fittings with a 9/16" wrench flats will fit the fuel female fittings
  2. The power steering fittings are 1/4" shorter than the male fuel line fiittings measure the depth of the female fitting before using
  3. Don't lose the o-ring that's on the end of the tubing
I just had another option, the supply line fittings to the fuel filter are the same size and lengh on both ends you can cut those off at a junkyard, I would also double clamp as has been suggested.
Old Dec 6, 2008 | 07:17 PM
Vader's Avatar
You can also adapt to the line with a steel compression coupler, then connect that to a Hoffman pressure hose connector. They are available through most reputable industrial hydraulics distributors, and are rated for fuels, oils, and gasses to 5,000 PSIG. They are the nuts for repairing oil cooler lines, too.
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
