bog down or hesitation on accelleration
Old Dec 4, 2008 | 11:31 PM
cs11091's Avatar
Car: 85 tpi iroc z
Engine: 305 tpi
Axle/Gears: 4:10
ok this has me completely baffled, i have been on this project for 8 months and i will try to be as specific as possible,i have a 85 305 tpi with a cold start injector , before i rebuilt the entire engine of the car i had a pre existing bog down, or hesitation problem, kinda as if the car isnt getting enough air , fuel, or restricted exhaust flow, i noticed the car would increase in rpm as i drove it and pressed the gas slowly and steadly, but if i floored it it was allmost like there was a rpm govenor. but if i was in park it would redline fine and then somtimes in park it would bog down, first thing i was told was a maf sensor, so i checked it and it had a ripped screen so i bought a new one $300, didnt fix the problem, next checked my distributor and rotor and cap and plugs and wires and correctly zeroed out the timing they all got replaced $500. then i started having idleing problems and black smoke, so at 160000 miles i said screw it i will just rebuild the engine, $3000 dollars everything got redone or replaced except for the crank, including all sensors except for the iac. new knock sensor $50 coolent sensors tps $60,cold start $100 etc... got the engine in and same exact bogging problem so replaced the injectors $550, replaced intake $150, replace water pump, radiator, goodyear hoses, $400 had the throttle body rebuilt $200, borla exhaust $1000, you get the picture come to find out i suddenly kept blowing fuel pump fuses, come to find out ecm was shorted somhow and blew a capacitor clean through the board, new ecm $110, also rechecked the entire wire harness wire by wire no shorts or bad relays, check and replaced all vaccume hoses and have check with smoke machine, i removed the catalitic converter thinking of exhaust restriction with no luck, ive cheked proper voltage on tps and reset iac several times. now she idles 1800 rpm and is barly able to accelerate. now heres the kicker when she shifts into 2nd 3rd gear when she is boging as soon as the shift happens it stops bogging down, and at high speed no bogging at all when i accelerate she will downshift and acclerate great, i have even tried adjusting my kickdown cable.
BTW: the comp is throwing no codes and no lights!!!!
please help <<< yes i know i am an idiot for ivesting this much money and i am running out of ideas
Old Dec 5, 2008 | 06:18 AM
tinymay's Avatar
Engine: 5.7 TPI
Re: bog down or hesitation on accelleration
High idle and stumbling until TPS says dump some fuel but runs fine with no load high rpm... my guess is a BIG vacuum leak. Maybe a stuck EGR? Ruptured brake booster?? Cracked PCV hose??
Runs fine pressing the gas slowly but flooring it makes a no go... Sounds like fuel starving. Fuel filter or pickup clogged or maybe crimped fuel line??
Anyways, before anyone else asks... can I have your old parts??
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Grant2k
Apr 4, 2016 08:21 AM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
