400ci TPI?
Old Dec 7, 2008 | 04:59 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
400ci TPI?
Yes I know this has been discussed but,
I know the TPI will choke the motor. So my question is, if I am producing 375 hp with a carb on my 400 ci wouldn't the gain over a 305 ci with the low power be better then running the 305? Or would it choke the motor enough that it would pull the power down to the 305 level. Don't have the money for a new intake but have the 400 ci sitting on the floor from when I used to race and the TPI is already in the car. Don't want to run the carb.
Old Dec 7, 2008 | 07:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 400ci TPI?
Assuming its an all-GM TPI manifold, you'll probably hover around 300-320hp, if you're making 375hp with a carb. Your powerband will probably end around 4200-4500 rpm.
Old Dec 8, 2008 | 07:41 PM
sol_searcher's Avatar
Re: 400ci TPI?
This article from the June 2003 Super Chevy might give you some insight into a TPI 406.
The link below is to AFR's website where the article may be found.
http://airflowresearch.com/articles/article093/A-P1.htm
Old Dec 8, 2008 | 08:06 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 400ci TPI?
The 400 may very easily make 375 FWHP even with the stock TPI runners. I made over 300 RWHP on a 350 with the stock intake runners, stock plenum, stock TB, and ported stock base. Peak HP was at 5,000 rpm. The TPI is resonant bound for peak hp between 4,600 and 5,000 rpm, but its not limited to 320 hp by a long shot.
Old Dec 8, 2008 | 11:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 400ci TPI?
Here's a thread about a 403 RWHP 406ci TPI/SuperRam engine:
https://www.thirdgen.org/forums/alte...fications.html
1986Z28OWNER
Dec 13, 2015 10:19 PM
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
