cam suggestions?
Old Dec 9, 2008 | 08:15 PM
smoove2022's Avatar
cam suggestions?
Hey guys
As listed in my sig, I have an 82 trans am that has the original 305 that i recently swapped a TPI intake on. It still has the stock block and heads but Im running the crane powermax 114132 (2040) cam. I installed this a while back to replace the stock cam that had a lobe rounded off. I'd really like to put a 'lopey' cam in with some 1.5-1.6 rr's and maybe go with the wp torquer 305 heads & a higher flowing intake base and runners. Unfortunately ive been out of the v8 scene for a bit and don't know a lot about cam specs. I could really use some advice as far as choosing a cam and rr's. I know my stock setup has solid (hydraulic?) lifters. Can i even run 1.5-1.6 rr's? What cam should I go with to increase flow, give my car some 'shake n' bake', & work with the torquer heads & intake? I've been reading some posts about lt1 cams, would this work for my proposed setup? I also was thinking of installing a supercharger in the near future.
Old Dec 9, 2008 | 09:29 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Re: cam suggestions?
If your going with a blower pretty soon, you should cam the motor around that. Go to the power adder board to get some advice from the blower/turbo/nitrous guys.
I'm putting an LT1 cam in my 305 after the holidays sometime. It's not a lot of cam, but much more than the 305 automatic cars got. I think its just a hair bigger than a stock tpi 350. Remember that the LT1 is a factory hydraulic roller. If you have a flat tappet cam in your '82, and I think you do, the LT1 won't work without a lot of work and more money. Now if your talking about the early 70s flat tappet LT1 cam, it would go in your motor, but would probably be a little much for most 305's
Old Dec 9, 2008 | 10:24 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
This has been covered many times.There is an article in the tech boards called"Opinion.What everyone should know" or something like that.Gives you a decent idea(IMO) of what cam you may need.lopey and tpi dont go together.LT1 with 1.6 rr would be a good choice for your 305.Almost the same as my LT4 w/1.6rr.Do some searching like redliterunner said.I`m sure your question has been asked and answered before.With stock heads I`d have some work done to them or go aftermarket.
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
