Which TPI do I have???
Old Dec 16, 2008 | 01:47 PM
Duffy21690's Avatar
Car: 95 Altima / 65 GTO (Project)
In my garage I have a 305 TPI with an automatic that supposedly came out of a Firebird that got rear-ended and it only has 40,000 miles on it, again, supposedly. I want to know which year range it is in. Whether it is the 80's or the 90's version. It has the alternator and air pump on the passenger side of the motor and the A/c compressor on the dirver side of the engine. On the passenger side of the throttle body there is a sensor that looks like Throttle Position sensor and then there is some type of sensor mounted underneath the throttle body as well and the plate on top of the throttle body read "Tuned Port Injection". Any help is great because I want to know what performance parts I need to look for because I plan on building it up as torquey as possible and sticking it in my Jag along with a T-5. Thanks In Advance Everyone.
Old Dec 16, 2008 | 03:14 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Which TPI do I have???
Alternator and air pump on the pass. side and ac compressor on driver side will be an 87 or earlier tpi. Is there a serpentine belt along with v-belts? 88 and up tpi's use a single serpentine belt.
Old Dec 20, 2008 | 10:06 PM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
most tpi's are the same, but the earlier tpi had a huge thing under the plenum, its a jiant rusty p.o.s. if thats there, its like 89 or earlier or 88 or earlier, i forgot wich one
Old Dec 23, 2008 | 02:59 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Can't you tell if it's an early model by the 9th injector?
Old Dec 23, 2008 | 07:05 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
MAF sensor and its 89 and older, MAP sensor and its 90 and newer
the fact that is say's "Tuned Port Injection" on the TB then I'd say its 88 or older, all the 88 and older I have owned had the "Tuned Port Injection" and all the 89 and newer I'v had didnt say anything, but I live in Canada so maybe thats just here
Old Dec 23, 2008 | 07:14 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
http://www.hotrodlane.cc/PDFFILES/TPIStory.pdf dont throw a bunch of oney into a 305 unless your on a mission to make a badass 305, or if you do, make sure your money is invested in parts that are interchangable with a 350,, not hard to do since thats almost every bolt on.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
