Fuel Pump sending unit to -AN fitting
Old Dec 22, 2008 | 09:40 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Is there any reason I cannot use the same fitting most people use from the hardline in the engine bay to braided -AN line that Earl's makes...but use it as the fuel line comes out of the tank? (connection right above rear end)
I want to run the lines towards the outside of the car and not through the tunnel..but don't want to sump the tank at this point either.
Would this work??
Old Dec 23, 2008 | 09:12 AM
tinymay's Avatar
Engine: 5.7 TPI
Re: Fuel Pump sending unit to -AN fitting
I broke the tubing to install an external fuel pump and filter. The only concern with braided hose is leakage. The pressure is not a problem.
Old Dec 23, 2008 | 09:53 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
From I have read ( and I could be wrong ) the compression/Swagelock type tubing fittings to go to -AN are only good below 40psi. I was planning on using a compression fitting going back into the tank on the return side because the pressure should be lower...
Has anybody tried this special fitting from Earl's?
Old Dec 23, 2008 | 11:56 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If that were true I would never have used them. I use Swagelok & Russell fittings.
Here's the Swagelok Tubing Data and is true regardless off manufacturer.
http://www.swagelok.com/downloads/we.../MS-01-107.pdf
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
