Pre 85 Block, 87+ TPI, what heads ?
Old Dec 18, 2008 | 09:05 PM
hzemall's Avatar
I did a search but couldn't get the actual info that I was looking for.
I have a pre 85 SBC crate motor, its a 290hp one (about 5000k on it) and I am using a 87-92 TPI setup.
What are some good/decent heads to use that are going to give me good performance and HP increase but nothing crazy.
I was told vortec, but the intake won't fit, I was told some L-98 but same thing.............I'm a little confused....
I am going to get a complete Comp Cam set up (cam, rockers etc).
The TPI was built by Arizona Speed and Marine
Educate a newb a little if you could.
Old Dec 18, 2008 | 09:19 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Pre 85 Block, 87+ TPI, what heads ?
The 87+ TPI intake bolt pattern is different, to fit 87+ heads. The four middle intake bolts go in at a steeper angle than pre-87. Vortec heads have a totally different bolt pattern, all intake bolts go straight down, and there aren't any middle intake bolts if I remember correctly. So 87+ L98 heads would work fine, including the aluminum ones from a vette.
Old Dec 18, 2008 | 09:26 PM
hzemall's Avatar
So if I am looking for a "new" solution, what would I be "asking" for as far as heads. L98 ?
Thanks for the help.
Old Dec 18, 2008 | 09:31 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Yeah, but 87 and up L98. Actually any non-vortec, non-LT1 87 and up heads should work. Edelbrock does make a TPI lower intake for vortec heads, but it's around $400.
Old Dec 23, 2008 | 06:38 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
world products makes an sr torquer head for 87-up. that was the reason I searched around for an 85-86 intake, so that I couldf put virtually any set of heads I wanted on it.
Cheers!!!
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
