screw in studs
Old Dec 20, 2008 | 08:32 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
screw in studs
can someone give me a link to some good screw in studs for l98 iron heads..... i want to use those heads for another project....the studs must work with oem stock style self locking nuts because im using the stock style self aligning 1.5 rockers..... i thought these would work but they wont work with stock style self locking nuts.... these heads will be used on a .495 lift cam.....
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 20, 2008 | 09:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: screw in studs
I don't see why they wouldn't work with stock-style rocker nuts...?
Old Dec 20, 2008 | 09:56 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: screw in studs
Try these, no hex just shouldered. You tap the head and the shoulder bottoms out on the head. I'd get one of those tapping fixtures to make sure you start the tap straight unless you have a bridgeport type of mill to do the tapping.
studs http://store.summitracing.com/partde...700+4294925232
tapping guide http://store.summitracing.com/partde...6&autoview=sku
Old Dec 23, 2008 | 07:57 PM
88fastgta's Avatar
Re: screw in studs
thanks man.....
Old Dec 23, 2008 | 09:44 PM
Air_Adam's Avatar
Re: screw in studs
Go to GM and ask for a set for an LT1/LT4 - the aluminum head LTx used screw-in studs, no guideplates, and stock style nuts.
The aluminum head L98 used screw-in studs, guideplates, and stock nuts.
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
