fuel pressure test port, looking for some type of T fitting?
Old Jan 8, 2009 | 07:54 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
fuel pressure test port, looking for some type of T fitting? i want to T off the test port so i can run my nitours and a pressure gauge.
Old Jan 8, 2009 | 08:15 PM
Russ-So Cal's Avatar
Re: fuel pressure test port, looking for some type of T fitting?
It is just a standard 1/4 inch flare with a schrader valve installed. You don't hook nitrous into the fuel system do you? The nitrous should go into the air intake stream, or be plumbed into the intake maniflod. You could then mount the fuel gauge and run a line directly off the fuel test port to read fuel pressure.
Old Jan 8, 2009 | 08:29 PM
jayk2k3's Avatar
Car: 85 camaro z28
sorry i ment, im already using the test port for the fuel on my nitrous wet kit. i need some type of t-fitting
Old Jan 8, 2009 | 08:36 PM
A 1/4 inch female flare with 2 1/4 inch male flares will do the job. Check the copper fittings in the plumbing area of Home Depot, Lowes, or what ever big box home center is near you.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
