Old Engine block/heads and 87+ TPI Help
Old Jan 15, 2009 | 01:48 PM
hzemall's Avatar
Hey guys, I have some questions and I did a search and found lots of info saying that it needs to be done, but not how to do it.
I have a Pre86 350 block, Pre86 Patriot Performance 2181 heads and I have a 87+ TPI setup with intake.
I know I need to mod the intake to fit heads (mounting wise)
What & how do I do this so it's done properly?
Old Jan 15, 2009 | 02:41 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Old Engine block/heads and 87+ TPI Help
Do an advanced search on this site for "bolt holes" and base
Old Jan 15, 2009 | 02:46 PM
hzemall's Avatar
Does anyone have the technical specs to do it so I can have a machine shop do it ? Or at least know where to get the spacers they talked about ?
I want to make sure it's done perfect.
Old Jan 15, 2009 | 03:21 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If you tell the shop what you need and show them they won't need any specs. It's simple to open the middle holes to fit bolts at the same angle as the outside holes. If they use a mill they will just set it up for the same angle as the existing outside holes, then cut the centers.
It doesn't require anything special and indeed most people complete this at home with a drill.
Old Jan 15, 2009 | 04:28 PM
hzemall's Avatar
Just so I get it right, just get them to machine the 4 centers to match the rest of the holes on the intake so everyone of them is the same ?
Old Jan 18, 2009 | 10:57 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
I have the intake base you would need without having to do any modification. I would trade it straight up if you'd like. It's just sitting in my garage right now. It's off an 86 TA with all the bolts going the same way. Only thing I ask is you pay shipping to get this one out to you and ship the other one to me. I will take everything off the manifold so you can put everything from yours on to it. What do you say?
Chris
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
