Accel Super Coil
Old Jan 17, 2009 | 07:52 PM
IrocZ_85's Avatar
Accel Super Coil
Hello again,
Sorry for all the questions lately, but I gotta get my IROC back on the road!
Will the Accel Super Coil fit under the TPI distributor cover?
Want to keep the stock look, the parts stores around here all seem to have the Super Coil in stock, and all claim they cant get the Brute Thunder coil.
I know I can get the Brute Thunder coil at Summit, but would like to save on shipping!
Old Jan 18, 2009 | 01:49 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: Accel Super Coil
Originally Posted by IrocZ_85
Hello again,
sorry but no the coil wont fit. Reason being is the tpi uses a small cap and remote coil due to space requirements. The large cap hei was used primarily for carb application cars due to large volume of room and coil could be placed under cap to save sapace and other reasons.
Old Jan 18, 2009 | 02:22 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Early style TPI (MAF) used the big in-cap coil dist also.
Old Jan 18, 2009 | 10:11 AM
IrocZ_85's Avatar
Yeah, my 85 TPI has the in cap HEI coil. The super coil will fit the application, I just want to know if it will fit under the rear cover.
Old Jan 18, 2009 | 03:15 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
huh..i learned something today..
reason why i stated what i did is my dads friends has a MINT all ORGINAL 1985 camaro z28 packing a LB9 and small cap HEI
i better let him know he better tell gm about their screw up
Old Jan 18, 2009 | 09:48 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
interesting, i just found out i need a new coil and was leaning towards the accel super coil. and was wondering if it fit aswell. i have an 86 tpi. so it will fit all tpi applications before 1990?
Old Jan 19, 2009 | 10:03 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I have the large cap too. The stock size replacement accel super coil should fit under the cover.
Old Jan 19, 2009 | 08:05 PM
IrocZ_85's Avatar
OK there may be some confusion as to what I am asking. Will this coil:
http://store.summitracing.com/partde...5&autoview=sku
fit under the stock TPI dist. cover. I know this coil will:
All the local parts stores have the first one pictured, the Super Coil for $49.99. I can order the Brute Thunder coil obviously, but the Super is a bit cheaper and naturally I would save on shipping. BUT if it wont fit under the distributor cover I will pony up the extra cash.
Old Mar 24, 2009 | 09:07 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I was looking into coils myself. The Accel one you are looking at, has its own top design because it isn't designed to fit under the stock cover.
At the bottom of the summit racing link you provided, check the 'notes' section. It states that the stock cover won't fit.
If you buy one, let me know how it works out. Once I finish my interior work, I'll be going under the hood next. Hopefully, next month.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
no green
Jan 9, 2016 09:22 PM
school boy
Oct 22, 2015 11:47 AM
Dragonsys
Sep 25, 2015 03:51 PM
