86 Z-28 TPI hesitation
Old Jan 30, 2009 | 09:42 PM
phunt82's Avatar
Car: 1986 Camaro Z-28
I put in an MSD ignition(cap/rotor/coil) into my 86 Z28. Now the car seems to be hesitating occasionally, and when I put on the air/heat it occasionally acts like it wants to stall. What should I look at? I also had a code 36 that I attempted to remedy, could that have something to do with my issue? I am looking for some help before I do something to get me in over my head. Thanks for any help!
Old Jan 30, 2009 | 10:13 PM
dj_justice's Avatar
Car: 91 Formula Firebird
Transmission: 4l60
Re: 86 Z-28 TPI hesitation
How is your idle quality? My car does exactly what yours does in addition to a rough idle all due to some bad injectors.
Old Jan 30, 2009 | 10:55 PM
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
my iroc does the same thing too! and i did all the msd stuff also. whats causing it? my idle is a little rough too and its bugging the *$#^ out of me!
Old Jan 30, 2009 | 11:37 PM
phunt82's Avatar
Intially the car idles a little bit high...thne it comes down into the 750-550 rpm range after a few minutes or a couple of revs. When it is driving the car runs like a scalded dog. I wonder if it has something to do with the MSD stuff. The car had basic replacement cap/rotor and original coil...it ran better, but not perfect before. the msd cap was a pain to get to fit on the stock hei distributor, i was wondering if that had something to do....i am just plain confused!
louishenry
Aug 28, 2015 09:41 AM
zayne0
Aug 24, 2015 07:22 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
