3 wire o2 hookup
Old Jan 30, 2009 | 04:51 PM
73duster's Avatar
3 wire o2 hookup
i just recieved the 3 wire o2 sensor part#afs74 i ordered. I know 2 wires are for the heater, but which is for the sensor? 2 wires are black and the other is blue on the weatherpack connector.
Old Jan 31, 2009 | 10:04 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 3 wire o2 hookup
The two black ones should be the heater. Measure the resistance between them. It should be pretty low (<1K ohm).
Old Jan 31, 2009 | 10:20 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The blue wire is the sensor, the other two are the power and ground.
And it doesn't matter which one is power.
Hook one of them to ignition source and the other to a good ground.
onebinky
May 8, 2004 10:28 AM
Rage13
Aftermarket Vendor Review
Feb 2, 2004 11:22 AM
TPIGUY
Aug 23, 2002 05:56 AM
hot_rod_swifty
Car Audio
Nov 26, 2000 11:31 AM
