motor transplant 88 to 91
Old Feb 2, 2009 | 08:30 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
So I have a mildly built 355 in my 88 IROC and I'm going to pull it and put it in my 91 Z28. I bought the 91 as a roller. All the wirring looks intact and in good shape, I know that I need to change the knock sensor. I'm going to weld up the hole for the 9th injector in the runners and the fuel rail. I couldn't find part numbers on the spark module. Other than the knock and map sensor I know I will need is there anything else that I need to change?
Old Feb 3, 2009 | 04:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: motor transplant 88 to 91
TPI?
If so, you'll have to swap the MAF sensor. Or you can pull the ECM from the 91 and all it's related TPI sensors over to the 88.
Old Feb 3, 2009 | 09:07 AM
WIll36's Avatar
Engine: 355, 408
Originally Posted by Viprklr
TPI?
Yes I'm very aware of that fact. If you read the last line of the post I mentioned that I already know the 91 is a speed density setup. I checked part numbers on the temp sensor and such they all seem to be the same the one major piece I couldn't find an answer for is the spark control module
Old Feb 4, 2009 | 04:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Must've missed that.
The ignition control module is interchangeable.
Old Feb 4, 2009 | 05:26 AM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
you couldn't find an answer on the scm,because speed density cars don't use them.
Spark control is handled by the ecm.
So,if your 91 roller has the w/h and 1227730 ecm,you should be in good shape.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
dag19
Aug 26, 2015 10:22 AM
MY87LT
Aug 17, 2015 08:43 AM
