SLP runners on a 305...plus whatcha think about my setup?
Old Feb 10, 2009 | 04:12 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Im pullimg my 305 and trans to clean up the engine bay and Im doing a few mods while shes out... right now I have stock 305tpi 143k with a rebuilt 700r4 2200stall and 2.73 drum rearend. Im installing a 3.42 pbr disc rear, ported tpi, rebuilt injectors from rich at cruzin performance 19lb, 6al n coil, rebuilt ,guide cut down, ported and polished 601 heads(replace 081) and a xe258hr12 with 1.6 GMPP roller rockers, headman shortys n ypipe. Finally this is my question... even though tthe tpi is made for the 305 will adding slp runners to this setup raise my powerband over the stock runners... Im falling on my face at about 4300rpms as she sits right now....also does anyone know what the CR will be buy changing from the 58cc 081s to the 53cc 601s using stock gasket? thanks
Old Feb 10, 2009 | 04:26 PM
David 91RS/Z28's Avatar
Re: SLP runners on a 305...plus whatcha think about my setup?
It's falling on it's face early cause the auto 305 TPI cars have dinky cams. With the new setup it should rev much higher. With my factory ported base, plenum, and runners my 305 peaked in the low 5k rpms IIRC. I shifted around 5500rpms. I had a Comp 210/220 .480/.480 112 cam and untouched AL vette heads, SLP Tri-y headers, exhaust, 3.73 gears, etc. 13.6's at 101mph and 12.8's at 109mph with an 80hp shot.
Old Feb 10, 2009 | 05:56 PM
J.P's Avatar
J.P
IN MY OPINION I WOULD STICK WITH THE STOCK RUNNERS IF YOUR STAYING WITH THE 305.-I HAD AN 86 T/A WITH A 305 COMP CAMS TPI CAM I THINK .454 LIFT?--I'M NOT SURE.--PORTED 305 HEADS EDELBROCK HEADERS NO CATS/SLP RUNNERS, PORTED UPPER BASE,1.6 ROLLER TIP ROCKERS.--700R4 WITH A SHIFT KIT.--IT WAS A FUN CAR.--I SOLD THE CAR TO SOMEONE THAT HAD MORE MONEY THAN BRAINS.--BUT I STARTED TO GET THE 3RD GEN BLUES.--SO I WENT OUT AND BOUGHT A 92 T/A 350 TPI .-ADDED THE SLP RUNNERS,HEADERS,EXHAUST, TPIS CHIP AND THIS CAR WILL RUN RINGS AROUND MY OLD 305 CAR.--AND I KNOW 305 CARS CAN BE MADE TO RUN.-BUT THE LOW END TORQUE YOUR GIVING UP IS WHATS NEEDED TO GET THAT BIRD DOWN THE STREET AND TO HAVE A REALLY FUN CAR TO DRIVE.------- YOUR STOCK RUNNERS WILL MAKE THE MOST POWER AND TORQUE WHERE YOU NEED IT ON THE STREET.
Old Feb 11, 2009 | 09:46 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Last year I helped swap TPIS runners on to a LB9 5spd car. The next time we were at the track the car did improve but only by a tenth consistantly. I would say stick with the stock runners, the money you would be spending on SLP's could be spent elsewhere. Like some suspension pieces so that lil 5.0L will 60ft hard!
Old Feb 11, 2009 | 11:04 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
The plan is to run her in some autocross this year but mainly itll be for weekends.
88SS6SPEED
Nov 11, 2015 07:05 AM
85 Jimmy
Sep 30, 2015 07:56 AM
alpine247
Sep 16, 2015 05:25 PM
toronto formula
Sep 10, 2015 07:31 AM
89fast5oh
Sep 8, 2015 09:55 AM
