Fuel Line Leak test
Old Feb 12, 2009 | 04:46 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Fuel Line Leak test
Hi,
I am interested in testing my new fuel lines.
Car : 87 IROCZ - TPI
Has anyone used the ALDL (terminal G) to turn on the fuel pump?
12 Vdc must be applied to this terminal to turn on the fuel pump.
How much current does the fuel pump draw?
Thinking about placing a fuse between the battery and Terminal G.
Best Regards,
Bruce
Old Feb 12, 2009 | 06:22 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Fuel Line Leak test
I've done it. I think it draws 10A or so.
Old Feb 12, 2009 | 10:25 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
It also just as easy to put a jumper wire into the oil pressure switch and run the pump. Its there in case the FP relay goes bad so the fuel pump will run once oil pressure is established.
should be right at the back of the engine on the drivers side.
Thats how I always check my fuel lines before going out on the road.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
