Two exciting gas tank questions
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Hi guys
Just pulled my gas tank (sucky job) to change the pump, and I have two questions.
My filler neck is loose in the tank, enough you can twist it, and it's obviously been leaking. What's up with that, and is there a fix?
Whats that little round plastic doodad about the size of a fuel pressure regulator that's part of the line bundle coming out of the tank by the driver's side frame rail? It had a rubber line on it and was mounted to the rear brake line bracket. It broke in half when I tried to get the line off. Whats it do?
Thanks.
Thanks.
Engine: tpi 305
Re: Two exciting gas tank questions
Figured one out. The doodad appears to be a little valve and charcoal canister that keeps the gas smell under control as the tank vents.
Still like suggestions as to the filler neck.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
You may be able to find a radiator shop that repairs fuel tanks that can handle the filler neck.
Mine wasn't totally broken, but it would leak when fully filled. I just replaced the tank with a new one.
After you get the tank fixed, don't let the fuel tank neck support the weight of the fuel pump nozzle. This is especially true if the nozzles have a vapor return system. I think this is the cause of the tank neck joint failing and causing leaks.
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
I know you can buy the necks seperatly, so it could probably be welded on.
However, welding on the gas tank I am sure takes a lot of precausions that I am not aware of.
My neck was damaged from what it looked like the previous owner took off with the gas nozzle at the pump still attached. Any time I filled the car up past half way, I'd have gas running down the side of the car... I had no ambition of screwing with the neck, so I just got a whole new tank at NAPA (I agree the tank removal/install is a sucky job). The plus I believe most if not all the aftermarket tanks come with the slosh bucket in them if your car did not originally come equiped.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
The only precaution is to fill the tank with water. This removes all gas odors that could ignite.
Engine: tpi 305
I got kinda lucky and a friend had a nice used tank for 50 bucks. It's all back together now.
What a relief.
What a relief.
AkDrifted
Aug 17, 2015 07:45 PM
