heads and cam combo
Old Feb 23, 2009 | 11:39 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
heads and cam combo
So i've done my time with researching and reading other threads. I now pretty much have my mind set on the xfi280 comp cam and a set of trick flow heads. now i'm curious as to what everyone else is running in their thirdgen. Lets post some heads and cam combo's and what your hp. & tq. numbers are.
Old Feb 24, 2009 | 11:42 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: heads and cam combo
do a search
Old Feb 24, 2009 | 12:09 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I'll go for this. Trick Flow 23 degree 195 cc runner heads and Trick Flow 246/254 .558/.558 112LSA hyd. roller cam made 405rwhp@ 6500 337rwtq@ 5000 through a 700r4 and a best e.t. of 11.44@ 118
The same heads and compression (10:1) and 264/271 .626/.626 114 LSA solid roller cam on 10psi made 633rwhp@ 7300 472rwtq@ 6400 through a 700r4 with a best e.t. of 9.9x@ 137.
Fuel injected the motor, dropped compression to 8.5:1, boost to 15psi, and through a th400 with a trans brake shown 586rwhp@ 7300 460rwtq@ 6400 and ran a 9.55@ 140.
Old Feb 24, 2009 | 10:08 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
See sig
Old Feb 25, 2009 | 05:03 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
not too bad i guess with the trick flow 23 heads and comp cam. but is there any other cam that can put out a bit more? while keeping the car not too radical.
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
