350tpi injector help
Old Feb 25, 2009 | 03:19 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
how do i know if the injectors are bad i ohm'd them and there all within spec but thats as far as i went also whats the stock sizr injector and what should i go to on a stock car
Old Feb 25, 2009 | 05:42 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: 350tpi injector help
if you need injectors call Jon at FIC www.fuelinjectorconnection.com
tell him Frank Burd said to call, he will give you a discount and great advice.
Old Feb 26, 2009 | 01:10 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Ohm them again hot. Heat soak often time changes the reading for the worse. 22 lb is stock.
Old Feb 26, 2009 | 02:53 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
ohm test wont let ya know if they are leaking tho. pull the rail, run some longer rubber fuel lines set the rail w/ injectors in it inside a bucket or tote. turn the car to on but dont crank it. if they leak with pressure in the line, time to replace them puppies.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
